Tested the stator and it seems to working correctly. Cleaned the battery ground to frame also.
Got a new battery and voltage rectifier. I will finish installing it tomorrow.
I tried to trace where p5 is grounded from regulator/ battery ground cable, do you know where it grounds to frame? If so would you have a picture. I just replaced battery and want to make sure is not corroded or loose. 👍
