P1000 Show your aftermarket rims
Delton
Delton
Honda Fanboy
9,967
31,488
Middle TN
Thanks. Trying to decide between the 28s and 30s. I’ve read the 28s are actually 28.25 and the 30s are 28.5. Maybe I should stick with the 28s if I just plan to do the HL lift and no arms.
My 30s measured 29.25" with 8lbs in them.
Reactions: Tsmith239
Pmed489
Pmed489
119
137
I just bought 4 of these for my PK1 couldnt pass up the deal 33.00 each
105757 Quadboss Scoville Boss 15x7 Matte Black Wheels
Reactions: Remington
Tsmith239
37
40
Are you still running the evos? And if so how do they do on pavement? My wife uses ours on the road quite a bit so that’s my only concern with the evos
Zax185
Zax185
76
181
Montgomery, AL
CA85BA80 CBA4 4CD0 A615 5F46E58D7646
Roctane 28x10x14 on ITP Tornado Wheels in 5+2 offset on all four corners
Zax185
Zax185
76
181
Montgomery, AL
Question, those QB wheels are rated 573lbs to 727lbs. Is that enough for a 1000-5 load down? My ITP are rated at 1,200lbs each. Just wondering
A
Average_Joe
970
3,676
Gainesville, Fl
  2. Other Brand
Just bought these 4 mud tires and 4 rims for my P1K5
Honda rims and tires
116,574
I am thinking about ordering these wheels for my pk1. Are those 3+5 and are you going to use 1 inch spacers on the back?
Yes, no I have 1-1/2 “ spacers on the back and 1” on the front. I have 30” LT MT tire with SATV forward arched arms
Tsmith239
37
40
Well I just realized the msa m20 wheels I ordered are a 0 offset. Does anyone know what size wheel spacer I will need to make them even?
Zax185
Zax185
76
181
Montgomery, AL
If I a thinking right, long day, you have a 3.5 + 3.5 and most of us are running 5+2 with 1” wheel spacers in the back to make it similar to a 4+3 since rear hubs are closer together. So with the 3.5 you will be wider in the front by 3 inches then 5+2 and I would still put 1” wheel spacers in the back to make it the same width.
Pmed489
Pmed489
119
137
Got first rim on wanted to verify it would fit. RB3 1 inch spacer Awsome product!
Got tires for 81.00 each Forecrum tires 235x75x15 on Quad Boss Scoville 15x7 rims
57696259276  9ADB2E7C AA84 4951 838D 8AAB99CA2F49
