P1000 Side step pipe rust issue
Neohio
Neohio
Beast of the East
21,739
93,107
Painesville Ohio
thank you sir
You're welcome.
Go with any schedule readily available. Sch 40 I think is available at the box stores.
Find a metal supermarket or something similar, ask them if they have any drops. Might find it for almost nothing.
JenElio
JenElio
82,158
714,210
Loxahatchee, florida
@JenElio do you recall what size pipe you shoved in there?
1 1/4 NPS pipe.
Actual OD of 1.660"
Ed Zachary ☝️
I picked up 2 10' pcs from HD. It's the same pipe I used to sleeve my cage when I chopped the top. I had to mill it down a bit to slide in the OEM pipe but maybe due to all the dents mine had already. I cleaned and pre-lubed the OEM as much as possible NoMo and it was still a real tight fit -SHE- 😂 the BFH took care of it though
Jankyeye
Jankyeye
883
4,189
Tampa, Fl.
Ed Zachary ☝️
Yea mine's a little smashed on one side. trying to work it out in my head how to get it back in shape
Reactions: JenElio
JenElio
JenElio
82,158
714,210
I took a grinder and beveled the front end of the pipe and literally had to beat the sleeves inside. I slid both sides in as far forward as possible and it straightened the OEM pipe back into shape. They've since took some hard hits and no damage at all aside from the cheap powder coat flaking.
Reactions: Jankyeye
Jankyeye
Jankyeye
883
4,189
Tampa, Fl.
No worries about bending anything (pushing it fwd) when "beating it" (lol)?
Reactions: JenElio
JenElio
JenElio
82,158
714,210
I had a lot of the plastics off already from other work so I strapped/chained down the structure from front to back. From the front and the cross supports back to the frame rails, worked pretty well because at one point I was using a 20# persuasion tool 😬😂
  • Haha
Reactions: Jankyeye
ToyMan
ToyMan
59
161
NV
Good idea, I bent mine on my old 700 the first day I had it. I will upgrade the 1000 soon.
ODAMO
ODAMO
1,388
3,657
Ohio
Since your sleeving it you can always try drilling a hole and using a dent puller before pounding it home.
mustsha1
Houston< TX
🤔....are these pics of the ones you had or the replacements?........I don't see these being bad at all to need replacing 🤷‍♂️
These are the originals they don’t look that bad but that’s because of paint is hiding it. It rusted from the inside out.
Reactions: JenElio
P
Prospector16
19
107
New Brunswick, Canada
Follow-update. Got them repaired by local welder. Turns out that stock car roll bar tubing is awful close to the same size. Put it all back together day before yesterday. All good for a while now- I just have to stay away from protruding stumps :).
F72A9EFE 18F4 4C13 B4D1 B72ACCD51FED 1 105 c
ABBDF564 D16D 4544 BBC7 C212DB7CFFE1 1 105 c
