P1000 Sidewall repair
ghost
ghost
993
1,874
BC
I got a puncture in the sidewall on my last camping trip.
I patched it and it was good for the rest of the trip. 3 weeks later I have a slow leak.
Is this a hopeless cause - or is there some plug / patch / liquid that will let me use this tire - safley ? Maybe just as a spare.
I have Blackwater Evos and ITP Beadlocks. Had to drive my truck over the tire multiple times to get the bead off.
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
might see if you can find a place locally that will vulcanize your tire. Basically the add more rubber to patch the hole. See pic below - they have to cut a area out or rather grind it down but it makes it stronger that original
2066A66D C7B2 400F 94A0 25A0B56A73CA
Reactions: ghost and JTW
Tuco69
Tuco69
1,474
7,565
Middle Georgia
Have seen this done to tractor tires. Worked great.
212,778
Been there done that, did you have it done at J & S? Mine is holding up well.
ghost
ghost
993
1,874
BC
What are you guys paying for the vulcanizing?
This was a weird one in the sidewall of my wife's rig I repaired yesterday. Maybe I've been lucky but yet to have a hole that tire plugs couldn't fix. Used over a dozen a couple times though
IMG 1576
Reactions: knuckledeep
Ragnar406
Ragnar406
The Great Bald One
4,460
17,085
Bella Vista, AR
Yep, thank you for recommending the place - I went the day after you posted on here.... good group of guys ... they even tried to give me a bunch of okra when I went to pick the tires up... said $30 for the tires but you have to take some Okra.
Amre2me2
Amre2me2
381
1,424
Colorado
For sidewall punctures, you can also put a tube in it.
Similar threads
