P1000 Size of enclosed trailer?
L
Lasaun
10
20
I am wanting to buy an enclosed trailer to haul my 1000-5 in, what size would I need to keep from having to crawl out the back or side of it? Could I open the doors in a 7'? Also, what would the height need to be to drive in with a ramp?
Thanks!!
Reactions: ChadD and Lady01
JimB1055
9
26
Tennessee
I have a 7x14 enclosed trailer and a Honda 1000-3. Its too small to get the doors open enough to step out. You would need a 8 x 14 to do that. I find myself crawling out the back. What ever you decide on don't forget about the height. More importantly, the rear overhead cross member. Remember the roof will add height also. This is a detail I overlooked, so now I have to air down the tires to get it in the trailer. Best to plan ahead. Good luck with it.
FiresteelFlyfisher
FiresteelFlyfisher
20
89
Upper Peninsula Michigan
Thanks!!
Dude, I have 2 Pioneer 1000-5s and the 2018 is an LE so its a little taller I recommend a 20 footer for 2 and get the special order
High gate opening 8'5" Tall by 8ft Wide is perfect amount of room to drive right up and into. PS get the power jack stand as well you wont regret it when you are 59 yrs old like me.
Rick
Brazula4life
81
97
Florida
7x16x7 I can fit my talon r lv and a 400ex with about 8 inches to spare. Tricky part is just loading the talon because the door cables. Just takes getting used to it. I'm 6.2 250lbs and I can open the door and shim my way out.
20210302 173457
BamaDave
40
112
South Alabama
I’m looking to possibly going with a. 7’ wide version with a “get out door” to help get my old tail out! This will reduce overall drag pulling a wider trailer around. Now you have to determine what other things you want to haul around when considering how long of a trailer you need! I’m currently looking at a a 16 foot version and a front side door for storing the hunting gear I’ll be needing!
5,759
26,449
How tall is your door opening so we’ll know what’s too low? Sounds like you have a roof?
Reactions: Lady01 and ChadD
