P1000 skid plate and plow kit question on 1000-5
tigerbite84
tigerbite84
22
89
Reinholds, PA
Hello all, does anybody have a skid plate on and able to mount the Honda OEM plow kit on? Will it work to have both on? Thanks
Robobrainiac
Robobrainiac
2,460
8,569
Someone else may chime in with their own experience. Mine is as follows
SuperATV skid plate
Denali plow package
I had to cut and remove the front of the skid plate to make room for my plate to install. I plan on removing the plate and reinstalling the piece I cut during the non snowy months.
A
ArcticSledder
25
70
Loretto, Minnesota
I have the same setup and with the full skid plate the plow mount will not fit 100% as only the bottom 4 bolts are able to screwed into the frame the front 2 bolts are off. I have plowed 2 seasons with this and it is a pain as the bolts shear off or back out. This season I got a welding shop to retap the 4 bottom bolts to a larger bolt and tack welded the bolts to the mounting plate so it does not back out. The front of the mount is welded to frame. We will see how this works this plow season. I did not want to mess with cutting the skid plate.
Vikes79
Vikes79
SKOL!
10,896
105,713
South Dakota
  2. Talon X4 LV
I don’t know of anyone having a Honda OEM plow…
most on this board seem to have a KFI, Denali (what I have from club store) or a Warn or something similar.
with my Denali plow, I had to cut the front of my Trail Armor skid plate back to allow the mount to work. I remove the mount in the spring. Cutting the skid plate back hasn’t affected its performance at all. I still have the piece if I wanted to reinstall with two extra screws.
I would say I cut about 6” off the front.
Reactions: Robobrainiac
ToddACimer
ToddACimer
Pioneer 1005-2
3,561
14,613
Oshkosh, Wi
The Warn mount fits tight under the front frame so most skid plates should fit with it. The Warn plow mount makes a good skid plate itself.
Reactions: Buggyman
