P1000 SATV skid plate P1k-6
Tramguage1
Tramguage1
Texan
7,600
31,472
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I will say there's a LOT of parts with this skid plate. I hope to get some time to install this in a couple weeks.
P
PetePoling
9
29
leo, indiana
The 2022+ should hit the website in 2 or 3 months. I ran it up the flag pole and they are going to get it into the lineup soon.
Seriously???? I just called superatv and asked if they plan to upgrade the skid for the 22+ 1000-5 and they said NO
so, I ordered one knowing that it wasn't going to be perfect for my '24. JUST got it in the mail a week ago and took a router to it to open up the three drain locations just to match the factory size and I see his post. Do you have ANYMORE info on when this will be available since it's been about a month since you posted this? I'd much rather sell this one (since I can't return it now) and wait.
Reactions: ChadD
Hello_Darkness
Hello_Darkness
664
2,671
Just to the right of nowhere
What's changed on the 2022+?
It's literally the same skid plate.
P
PetePoling
9
29
leo, indiana
from the looks of it, its vastly different on the side pieces... the shape is the same but none of the original mounting locations are used, it's all self-tappers or riv nuts if you go that rought. You also can't use the metal strips that go behind the front tires due to the different inner fender plastic on the +22
Reactions: ChadD
Hello_Darkness
Hello_Darkness
664
2,671
Everyone else sells the same skid plate for 2016-2024?
SuperATV
SuperATV
1,738
12,739
Madison, IN
www.superatv.com
Small changes that required small modifications to our design. 🤷‍♂️
The earlier design works too...you just need to play with it like Jackal did. The newer one just makes install a little easier on the 22+ models.
Reactions: ChadD and Remington
282,960
SATV fitment in detail here difference from '16-21 vs '22+
Hello_Darkness
Hello_Darkness
664
2,671
The other 2 brands I've installed say 16 and up🤷🏻‍♂️
Reactions: ChadD and JACKAL
282,960
Ya I doubt any fabricator of the uhmw skids has bothered to change their pattern as it "Technically" works for all model years. But if they did update the holes locations they would save the installer from drilling 26 unnecessary holes that could be used by 22+MY updated attachment points with M6 threaded holes already in place all within 3" of the "old" patterns
