The branch came up through the bottom and out the side .How will changing the skidplate on the bottom help with side cover??
Did you have the rockers protected as well? Or just the center body?The branch came up through the bottom and out the side .
Just the stock centerDid you have the rockers protected as well? Or just the center body?
Yeah, I learned the hard way, got to add protectionJust the (factory) skid?
Ohh yeah that stock skid is like a G-string, I thought the OP was that even with the ricochet skid it busted through it. My bad! Definitely get some protection down there man, I did mine and to me I consider it one of the best investments. Good luckYeah, I learned the hard way, got to add protection
Oh, my bad. Yeah was out there commando. Just wanted to know if anyone thought the hybrid alum/plastic was the way to goOhh yeah that stock skid is like a G-string, I thought the OP was that even with the ricochet skid it busted through it. My bad! Definitely get some protection down there man, I did mine and to me I consider it one of the best investments. Good luck
I did the 1/2” UHMW from trail armor and love it, I’ve bounced it pretty hard a couple times, no problem, it also seems to slide over the mud/ruts real easily, very happy/glad I added it.The UHMW I think is what most people lean towards, they hold up the best I've been told. I made mine out of 1/4" aluminum, going on about 6 months now and its taken a few beatings like a champ. I don't ride much over extreme rocky terrain, mainly mud/rutts/wooded trails and I love it so far.
AmenTrail armor is the way to go, aluminum wont slide on rocks if you dont have rock go for it
For sure I made mine from 3/8 aluminum because a got a ridiculous deal on it. I did notice that others slid right over ruts that would hang me up. I dont regret my choice because when I bolted the skid to the crossmembers it pulled them straight and cured a high speed decel vibration that I thought was normal. Its piece of mind that in no scenario should I have a hole in the bottom that I didn't cut.Trail armor is the way to go, aluminum wont slide on rocks if you dont have rock go for it
