P500 SMELL GAS
maddmax
257
231
Clarksdale Ms.
After I ride for about 30 min. or so in the woods,I keep smelling gas.Can't find a leak anywhere.
Fordman
Fordman
160
272
Fayette Al
Hmmmm , sorry I've never had this problem before, maybe some of the others can help
jak9922
jak9922
hot headed wopolock
3,282
5,635
pittstown ny
If thats not it and you dont see any leaks then its flooding out did u notice any powerloss check the air filter they get filthy fast i clean every ride
271,077
I haven't noticed it on my little trips. Other than gas cap not tightened properly, maybe fuel tank filled too full coming from vent tube under passenger seat? The vent tube is clipped to the frame just out of sight on this pic in the lower right corner, if you see the black zip tie in the bottom corner of the pic it goes around the clip holding the vent tube.
20150911 161335 zps680hlczn
jak9922
jak9922
hot headed wopolock
3,282
5,635
pittstown ny
Jackal thats a good point too definitely if its an extremely hot day looks the the evap is right behind the riders
scott
scott
1,212
1,354
lyman, South Carolina
I saw the post and was like that's funny. On my 700 sunday i smelled gas idk why or what was going on. Didn't happen again.
Tramguage1
Tramguage1
Texan
7,393
29,872
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
My 700-4 I have intermittently would smell gas when walking by it while parked. Don't recall smelling it while riding, but after stopped and turned off for a minute or so.
66,391
Was it full FULL or just full. If u know what I mean?
If it was overfilled it is possable some could have leaked out the vent. Which is right under the passanger seat.
Tramguage1
Tramguage1
Texan
7,393
29,872
Somereset, Texas
  2. 1000 6 Crew
  3. Talon X
  4. Talon R4 LV
I havent filled mine completely . I just add 5 gals. Whenever it gets down to 1 dot on the guage.
hambone
hambone
154
89
Southeast Indiana
I would think vent also. If you look at picture, the white plastic 90 should be a check valve.
I haven't smelled gas, 1,000 miles, but you never know. If I did I would route the vent line higher and go from there.
maddmax
257
231
Clarksdale Ms.
It was not filled to the rim. Is the checkvalve you speak of in the top of tank,Thanks. Also this was not while riding,just afterwords.
Nathanp500
Nathanp500
21
64
Somerset, WI
I am having a gas fume smell when i come to a stop after riding. This is a 2017 p500.
