snorkel
michaelbach
48
7
Put a snorkel on over that past few days and ran all my vent lines, came out nice. Easy job, I'd post a picture if i could.
michaelbach
48
7
I might have some pictures coming. The pioneer did great, everyone was impressed. My mode button stopped working though:( anyone have this happen on a Honda before?
motoup46
6
12
0
Hattiesburg, Mississippi
Be careful what pictures you post on here. If your dealer or Honda sees them and can trace them back to you your warranty will be NULL & VOID!!
O
obenchain1
6
0
0
hey michaelbach did you do anything to your electronics box under the seat when you snorkeled it ? I'm in the process of doing mine now . Any pictures of yours?
coonhunter70
5
I'd like to add that for anybody that takes the occasional plunge the fuel tank breather tube is way to low. for mine I ran a longer piece of tubing up behind the seat back and then curled it back downward. This is easy to do when your changing oil.
64,636
I know you talking about a P5. But take a look at my Anouncement with the breather hose for the P700. viewtopic.php?t=1570
This seemed to be a set back for many that gave them trouble after they were sunk.
Easy and simple fix that will prevent the fuel tank from becoming a water siphon.
michaelbach
48
7
I ran everything up front and rear diff, fuel tank, and there is a breather on the radiator fan also
O
obenchain1
6
0
0
michaelbach; how high did you run the breathers ? And did you do anything to your electronics under the seat ? Any die-electric grease or anything? Here's mine that I did tonight . It holds tight . If i put my hand over the tubes it shuts the motor off. And I drove around like this with it mocked up, and I didn't notice any loss of power even on the top end .
michaelbach
48
7
Mine is only a couple inches higher than yours. The breathers up front I just ran them up next to the display under the hood. Ones in the rear I ran then up just as high as my intake. I pulled apart ever electrical connection I could get me hands hon and put dielectric grease on it. And yours looks good!
O
obenchain1
6
0
0
Thank you , I put the die-electric grease on the computer connections under the seat . Did you do the lights and everything ?
michaelbach
48
7
I didn't do the light socket itself but I did do the connector in the wire harness. I pretty much just folloowed the harness and where I could take a plug apart I did. Also if you end up riding a lot of water or deep water you might want to take the display apart and silicone it up. I learned the the hard way when I had water over the dash for a good couple seconds and the button on the display stopped working. Took it out got all the water out let it dry and sealed her up, no problems since
michaelbach
48
7
Re: Share your Pioneer 500 photos
