Unless you attach snaps to your window and roof. I don't recommend it... it stretches out and the back plastic clips come off and beat against the ROPS and break. It also stretches it out... But if you are only going 45mph it's ok but it looks like it's about to give birth...
First thing I would do is put silicone on the ends of the rods and rubber mounts cause they slip out and poke a hole through the top... and when you trailer it just take off and tuck away and if it's siliconed together you can leave rods in place while trailering..also if your happy where the mounting blocks are, pop them off ROPS and put a little silicone on them. Cause if you lose one you can't buy just them..
