Yes i have one on my 700. The quality of the paint and workmanship is TOP NOTCH. I know that he is swamped right now, but it will definitely be worth the wait.
I have the rack and have been using it since November. When I swing mine open it sags real badly and I am looking for a way to correct this. You mounted yours using the rubber strips? If so did you use both the thick and thin strips?
I mounted mine higher than you did. The brackets are above and below the roll cage joint. Wonder if the tubing size is different, will have to check it out.
Also my brackets slant to the inside from both sides not allowing the bushings in the rack to ride flat on the bracket. Is yours like this?
Lots of questions, but I appreciate your help.
JakesDad
