P700 Spare Tire Rack
JakesDad
7
Anyone put on one of the Brick City spare tire racks made by Moses?
Thanks
Jakes Dad
Ratchetdan
Ratchetdan
29
26
Alaska
No but I did recently pm him about one and he said that they are currently out of production for a couple of months.
7,197
27,840
Yes i have one on my 700. The quality of the paint and workmanship is TOP NOTCH. I know that he is swamped right now, but it will definitely be worth the wait.
20170201 170810
Reactions: joeymt33
7,197
27,840
Look him up on Facebook, you can see what he does.
JakesDad
7
I have the rack and have been using it since November. When I swing mine open it sags real badly and I am looking for a way to correct this. You mounted yours using the rubber strips? If so did you use both the thick and thin strips?
I mounted mine higher than you did. The brackets are above and below the roll cage joint. Wonder if the tubing size is different, will have to check it out.
Also my brackets slant to the inside from both sides not allowing the bushings in the rack to ride flat on the bracket. Is yours like this?
Lots of questions, but I appreciate your help.
JakesDad
