Was thinking either getting cubes for the front or the Rough country wings with lights . Could I put a splitter off my high beam trigger? Does the store offer one?
Splitter?? Are you meaning you want to have some aux lights come on with the high beam? If that's the case, use the high beam positive wire to trigger a relay to switch added aux lighting. The relay contacts would be powered by a separate fused circuit.
Yes the club store offers a nice one. They offer one light bar and the trigger that’s plug and play or just the trigger that plugs into the high beam and you use your own lights. It’s a great add on. I used the trigger with my own 12” light bar on front run through a 7 pin rocker so it comes on with high beams on one side or just on by itself.
Plug-N-Play wire harness for easy installation. Hookup a Small to Medium LED light bar with ease 2ft lead allows easy wiring to the accessory. An easy fix for the dim factor headlights by installing an extra high beam light bar. Plug-n-play install. No modification to the stock wires at all...
