P1000 2022 Pioneer 1000-5 Deluxe High beams not working
Lady01
Lady01
192
488
Midland Michigan
Unfortunately I don’t think that schematic is correct for the 2022.
Probably not, but the concept of the main relay to the low/highbeams should help to diagnose the headlights... ensure voltage from headlamp swtich to main is available then from main to low/high beam relays... knowing the relay set up should be beneficial for you.
Neohio
Neohio
Beast of the East
21,558
91,338
Painesville Ohio
Probably not, but the concept of the main relay to the low/highbeams should help to diagnose the headlist... ensure voltage from headlamp swtich to main is avaialbe then from main to low/high beam relays... know the relay set uop should be beneficial for you.
I think I have a '22 manual at home. I will take a peek in an hour or so when I get there.
