P500 Squeaking
115,709
Wash it good in that area then try it. If its still there, take the wheel off and inspect the brakes. Might also have a dry rear barring. You wont know till u physically tear into it.
F
Fischer
209
321
The woods
I am hearing a little squeaking when I roll the 500 forward or back. It sounds like it is coming from the disc brake in the back. Anyone else having this noise? I'm wondering if there is a small stone caught in there.
I had and still have the same issue. Took it to the dealer under warranty. Still does it. If you figure it out, let me know.
F
Fischer
209
321
The woods
Mine has that squeal also. I think mine is in the rear disc brake. Or maybe a rear wheel bearing. Mine has over 4,000 miles on it. LOL
Yeah, pretty sure mines in the rear disk. The sound hasn't gone away. I'm starting to think, if it doesn't make numerous noises, it isn't a Honda Pioneer 500.
Morpheus
Morpheus
109
362
Minnesota
I have a squeaking in the rear brake assembly periodically. I attribute it to rust/dirt build up. It's usually most prominent after the machine sits for a bit. I get going around 7-10 mph and lightly apply the brake for a few seconds and it clears the disk and stops squeaking. It's something to try if you want.
Todd627
Todd627
56,720
619,275
MI
^^^^This^^^^
My P500 used to do the same thing. I would slightly apply the brake while driving like @Morpheus said, and it would go away.
kosh
kosh
42
104
Ste. Anne, Manitoba
Thanks for all the input. I sure sounds like it's the rear disc brake. I'm going to give it a good blast of water to try to dislodge any grit that might be there.
Reactions: Morpheus
sporttrac4x4
sporttrac4x4
1,177
2,083
ILL.
Brake pads also have a metal wear indicator that drags on the rotors when the pads are worn out. This will make a grinding or squealing noise.
Reactions: Morpheus
Chris36695
Mobile, Alabama
For a couple years, my 2018 700-2 had a chirping squeak from rear brake that came and went regardless of braking or accelerating. I finally fixed that irritating squeak. If the metal brackets that hold rhe pads in place are not just right, they each have a little tab that can rub rotor. I moved one bracket some and the squeaking has finally stopped.
Reactions: HiFive and Morpheus
Red500
Red500
6,044
65,479
Greeneville, Tn.
Had a rock in mine once. It would squeal and chatter bad when hitting the brakes. Took pads off and a little tiny rock fell out and the problem went away.
K
KPM
42
124
Prairieville LA
I had a similar issue with the rear brake making noise. Took it apart and it had globs Of dirt, grit and small rocks. Cleaned re installed and good to go.
Reactions: HiFive
