I am hearing a little squeaking when I roll the 500 forward or back. It sounds like it is coming from the disc brake in the back. Anyone else having this noise? I'm wondering if there is a small stone caught in there.
I had and still have the same issue. Took it to the dealer under warranty. Still does it. If you figure it out, let me know.I am hearing a little squeaking when I roll the 500 forward or back. It sounds like it is coming from the disc brake in the back. Anyone else having this noise? I'm wondering if there is a small stone caught in there.
Mine has that squeal also. I think mine is in the rear disc brake. Or maybe a rear wheel bearing. Mine has over 4,000 miles on it. LOLI had and still have the same issue. Took it to the dealer under warranty. Still does it. If you figure it out, let me know.
Yeah, pretty sure mines in the rear disk. The sound hasn't gone away. I'm starting to think, if it doesn't make numerous noises, it isn't a Honda Pioneer 500.Mine has that squeal also. I think mine is in the rear disc brake. Or maybe a rear wheel bearing. Mine has over 4,000 miles on it. LOL
^^^^This^^^^I have a squeaking in the rear brake assembly periodically. I attribute it to rust/dirt build up. It's usually most prominent after the machine sits for a bit. I get going around 7-10 mph and lightly apply the brake for a few seconds and it clears the disk and stops squeaking. It's something to try if you want.
Had the same issue, found a piece of gravel hung up....I am hearing a little squeaking when I roll the 500 forward or back. It sounds like it is coming from the disc brake in the back. Anyone else having this noise? I'm wondering if there is a small stone caught in there.
Had a rock in mine once. It would squeal and chatter bad when hitting the brakes. Took pads off and a little tiny rock fell out and the problem went away.
