Stealth Snorkel Examples - Honda Pioneer 1000
Chet
19
24
WV
Uni Filter 2-stage Angle Pod Filter 58mm I.d. X 102mm Length Up4229ast Amazon.com: Uni Filter 2-stage Angle Pod Filter 58mm I.d. X 102mm Length Up4229ast: Automotive
Heres the filter
2"x 3" fernco coupling
2" pvc street elbow and a short piece of 2" pipe
I turned down the 2" pvc (2.375 OD) to 2.25" OD help the filter go on and off better for maint.
Sent from my SAMSUNG-SM-G890A using Tapatalk
Did the smaller pipe dia. restrict the air flow and power on your machine?
Chet
19
24
WV
Mdtfc
Mdtfc
50
90
maryland
I'd like to do one straight off the air Box, up between the bed and seats. Then do away with all the piping up front. Anyone running that style?
Reactions: sharp
Check out the white lightning build, snuff did intake like you're describing.
A7e84ca263a723e2912efe908680e97d
Reactions: sharp and Mdtfc
GlockMeister
GlockMeister
The Bearded Wonder
7,606
35,593
Greenville, Mo
Reactions: sharp
Spoof0ne
42
55
New Hampshire
There have been lots of snorkel examples lately. Figured I would add another.
You will also find this same option and a few other in the DIY Snorkel thread here - DIY Snorkel
Hi Hondasxs,
Have you installed a dual battery after this? Did the snorkel affect the install?
Also, any issues with the hood rattling after removing the stock set up with the rubber stopper?
68,248
No and no.
No rattles from loosing that support.
Dual battery is on the list but I really dont have that many accessories to need it. Many say get it for the winch, but I never get stuck. Lol.
I have the isolater already. Guess I'll wait till my battery runs dead out all alone on the trail before it gets put in. It will happen one day. Hahah.
Mollie46
69
86
AZ
This style I am calling a stealth snorkel because it requires no modification to the the unit and can be easily reverted in a few seconds. The only issue I personally have is a prefilter but several users have found a solution. I will post those also.
Supple list :
Insulation is easy.
  • Remove the black cover.
  • Install the silicone reducer
  • Insert the hose
  • Run the line. I ran mine center between a metal bar up under the dash.
It was a tight fit so I did not see a need for a clamp. But if you don't check your rig often you should consider a hose clamp or something. I also found no need to seal the hose. It too was a tight fit and I see very little probability of water getting past it.
I never have plans to go this deep. But I have found myself fairly deep by mistake. I also like to run through creeks fast on a hot summer day and after hearing about all the water entry trouble I figured this might save me a hefty bill.
What filter did you install on the tubing?
