steering rack bushings.
Killer223
Killer223
265
529
I have play in my steering rack. 19 R, what all do I need to order? just the 4$ bushings? or the whole inner knuckle.?
How hard of a job is it to replace these?
Reactions: Plumber32
66,813
Bushings are a piece of cake
If you have to pull the rack the diff has to come out. Which means the stupid driveshaft clip has to come out. Then you have to take the front shaft loop.
We've gotten around removing the floor to get the shaft loop out. But the clip in the diff is a pain. We either, rip it out with a pair of vice grips on a slide hammer or if the rack is bad we just grind the lower edge of the rack adjusting nut off to clear the diff.
Grinding the rack let's you keep the driveshaft clip in the diff and just slide it foward enough.
Killer223
Killer223
265
529
does the rack have to come out to replace the bushings?
PaulF
PaulF
1,462
4,810
If past experience (and by the looks of the exploded view from the service manual) are any indication, I think you will find that the bushings are split/collapsible and held in my a outer "lip" of some sort. That means the rack needs to come out of the housing and that will require a complete steering gear breakdown. So yes, I would say an entire steering gear box removal is necessary...
1606373248797
[1] End Bushing...
1606373187295
SLOWPOKE693
SLOWPOKE693
1,641
6,281
Somewhere in Texas
I wish Honda would have put a grease fitting or two on the rack when they designed it. That lubed for life upon assembly crap doesn't work in the environments we ride in.
