Street Legal Kit for the Talon
stellarpod
stellarpod
821
3,025
OKC, OK - USA
I'm soliciting opinions on the best street legal kit for the Talon. Is there a good kit available that includes a stalk-type turn signal switch that would mount to the steering column, rather than the usual two-position slider switch?
What have you used?
Steve
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
The Ryco 3107 kit is almost plug and play. It has 5 wire taps (one at the brake light switch, 2 under the air filter cover so you can use the existing brake lights as turn signals and 2 at the tail light for the license plate light). It is Talon specific and the quality and instructions are top notch. It has an auto cancelling electronic flasher (n case you leave a turn signal on too long) and dash indicator LED lights. It also has DRL's and Flashing Brake Lights (both can be disabled).
Don't know if we are allowed but here is a link to one...
Ryco UTV Turn Signal/Horn Kit
stellarpod
stellarpod
821
3,025
OKC, OK - USA
That looks great! A bit spendy, perhaps, but more like what I was looking for. Appreciate the heads up, PaulF.
Steve
Dwight
27
Kansas
I've used the Ryco kits on the last 2 rzr's I've owned. Spendy yes, but I really like them. Wish I had the auto cancellation!
Dwight
Reactions: stellarpod
viceversa
viceversa
20
Flagstaff, AZ
That Ryco kit looks nice! anyone have it installed? curious about turn signal stalk mounting position and any issues with paddle the shifters.
stellarpod
stellarpod
821
3,025
OKC, OK - USA
I agree, viceversa. I'd like to see the mounting instructions or a video specific to the Talon, as I'm concerned about how the stalk mounts to the column. The Ryco kit looks to be the front runner at this point. Maybe I'll give them a call and chat about it.
Steve
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
I have installed it. The Stalk mounts to the bolt where the tilt piston is mounted (bolt replaced with a longer supplied bolt and spacer). I was concerned when I first looked at it but it is solid!
A word of caution! If you are tall and have long legs like me (6' 4" with 36" inseam), your knee may interfere with the turn switch. It took me a few drives to get used to it and make minor adjustments to the wheel tilt and my leg position. Now I hardly notice it but I may still fabricate another mount and move it higher. Or I may fabricate some seat spacers and move my seats up and back a little so I can straighten my legs a little. Or perhaps I may do both :)
stellarpod
stellarpod
821
3,025
OKC, OK - USA
Really good info, PaulF, especially since I am indeed 6'4", albeit with a 34" inseam. I wondered about that very issue, so your post is quite timely. I just got off the phone with the folks at Ryco and they're sending me a PDF of the installation instructions. But, the info you've supplied I suspect will not be covered. ;)
Thanks again!
Steve
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
Thanks again!
Steve
That 2" difference in leg length is actually quite dramatic. I hear about 6' 4" people that do not have leg room issues and I always have them. I assumed that anyone my height would suffer like I do but that is just not true. Your inseam is closer to someone that is 6' 0" to 6' 2" so your torso must be long like someone that is more like 6' 6" to 6' 8" tall so you probably have some headroom issues and I don't.
stellarpod
stellarpod
821
3,025
OKC, OK - USA
Actually, my height is more in my torso, but I don't have any headroom issues in the Talon.
QUESTION: Did you mount all three turn signal LED's in the front as per their template? I think it might be good to mount one of them on the side so that it would be visible from the side - especially as I have the Honda optional bumper mounted in the front which could obstruct viewing the LED.
Finally, since their installation instruction photos are not all Talon-specific, would it be possible for you to post a few pics of the switch stalk as mounted, the location of the panel indicator LED's, and perhaps the front signal LED's as mounted? That would be most useful.
Thanks again for your input, as it is much appreciated.
Steve
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
My Talon is in for 100 mile service and I won't have it back till next week so no pics available right now.
  • I mounted all 3 turn signals up front (I just have the stock bumper) but the wiring is long enough and there is some separation between the LEDs to provide some flexibility on mounting location. There is enough wire where the LED's separate that you could probably mount the LEDs 6 to 8 inches between each one of them if you wanted.
  • You can mount the inside indicators just about anywhere you like, there is plenty of wire. I had a kit on my previous SXS and mounted the turn indicators in the dash in between the steering wheel spokes. Driving a SXS you tend not to look there so many times I never saw them flashing and I was a blinker geek for miles. On my R, I decided to mount them in the center for 3 reasons.
  1. There is really not a very good place on the dash in the steering wheel area.
  2. I glance at the electronic display a lot so a blinking green light would most likely catch my attention there more often.
  3. My passenger can see them and alert me too if I leave a blinker on.
Here is a generic pic of a Talon dash pointing out what I did.
Upload 2019 7 3 12 31 14
stellarpod
stellarpod
821
3,025
OKC, OK - USA
Thanks, PaulF. I hadn't considered your logic on mounting location for the interior indicators, but it makes a lot of sense. I'll probably do likewise. And, because I've already got the accessory switch panel covering that cubby hole in the dash, I'll likely just mount them on each side of the panel.
I'll probably mount one of the three exterior LED's (per side) on the side, unless you think it needs all three up front in order to present a bright enough signal.
I just recently did my 100-mile service on my 1000X (did it myself, as I'm just too cheap to pay Honda to do it). We've got about 150 miles on ours now and we've been overall very pleased.
WHEN you get yours back, if you could snap a quick shot of the mounted stalk and post it here I'd very much appreciate it.
You've been a wealth of information, sir. Thanks again.
Steve
Reactions: Dwight
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
Steve,
Here are a couple pics. Not very clear but you should get the idea...
20190710 184913
20190710 184917
tumbleweed
tumbleweed
31
31
North Platte, Nebraska
Help!!!!!
Can anyone explain where the tail light harness is located? I'm installing the Ryco kit and the picture is not explaining it or I'm just frustrated. Any pictures or more details would greatly be appreciated. I'm on the bottom side of having it done and don't want to make a mistake.
tumbleweed
tumbleweed
31
31
Help!!!!!
Lost is found time to call it a day. Finished the install totally impressed with the Ryco kit,
as mentioned plug and play
bionicman
37
49
seattle
Anyone have issues with Ryco kit causing passenger tail light only to be inoperative??
fustrated
Reactions: Trlrdr6
I assume you’re drilling holes for the front LED turn signals?
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
Yes, you have to somewhere in the location of your choosing. I originally put mine in the dash just below the first cubby hole but now chosen to move them to install the radio. I have decided to relocate the instrument panel in front of the steering wheel (like I think it should have been from the factory) and this is my new location for my turn indicators. This mod is not for the faint of heart, there are some delicate electronics in there....
Upload 2019 12 10 9 59 6
But on a side note, that module appears to be pretty waterproof. There is an o-ring where it splits apart (it is not glued together like I thought it would be) and a boot on the wire harness.
