P500 Stuck in 4WD.
Y
y2juice
Hello All,
Newbie here with a new 2016 P500. I just picked it up yesterday and only had time to drive it around the yard a few times. I've noticed that the indicator says it's in 4WD however the Lever says it's in 2WD. moving the lever up and down, shifting up and down, on/off, other simple troubleshooting does nothing.
It literally only has 1 mile on it and has been it that way since I brought it home. Before I take it back and have the dealer check it out does anyone have any ideas? I'm thinking maybe there is a cable tension problem. Not sure.
Anyone have any suggestions?
Thanks all
Y
y2juice
Pretty simple fix once I figured it out. Long story short I took the hood off and disconnected the cable from the adjustment block. Once I did that the machine instantly switched to two wheel drive. Which lead me to believe the cable was out of adjustment.
Pulled the front passenger wheel and found a plastic cover over the cable at the transfer case. Pulled that cover off and found another adjustment point. Little adjustment and we're good to go.
I was bummed to have to work on a brand new machine BUT it was sweet to work on something perfectly clean.
270,891
Another built on Friday afternoon quirk :)
Reactions: Russ989
P
Pedel
6
Houston
Your detailed description helped me take care of the transfer case control cable and now it works as a charm. I did a lot of useless research before a found your article. Thank you very much.
