I recently installed a SuperATV Pioneer 1000 scratch-resistant flip windshield on my new P 1000-5 SxS. I mounted the bottom portion as low as I could possibly install it without damaging anything, and I installed the top section the same. The problem is, I can't get the two faces to match up where I would put the foam strip. Either the lower section needs to go about a 1/4"+ lower, or the top go about a 1/4"+ higher.
I have tapped both sections, higher or lower, carefully with a rubber mallet, but they are as high or low and won't move anymore.
For those of you that have installed this windshield, did you run into any similar problem? If so, how did you resolve it?
