Used my 2 yr. old winch for the 3rd time today and find the OUT function does not work. It makes a noise and I feel a vibration in the solenoid but nothing at the winch. IN & Freewheel work fine, all connections tight. Any thoughts?
Same result with rocker and remote, would that indicate not a switch issue or not?I had this very same problem 2 months ago , in my case , it was the Rocker switch that was bad!
I would say the switch is fine then but I am no expert.Same result with rocker and remote, would that indicate not a switch issue or not?
Yes easy access to the solenoid but the SXS is at my hunting camp 100 miles away, I'll try the wire swap soonest.Do you have access to solenoid? swap the two wires. the little black and green. the two outside wires on the solenoid. Wire F and G in diagram.
I have ordered a solenoid won't go down until I receive it. Not sure I understand what swapping positive and negative (A&B) wires will do, except make a lot of sparks, right? Please explain.If it is important to have it working while you are there. I would suggest bringing a solenoid with you.
Winch is still usable with its current problem. you can always free spool the line you need and power in if needed.
If swapping wires does not work. Try swapping A and B in the above diagram.
That will identify whether the motor or solenoid is faulty.
Really, didn't know that, Thanks.no sparks at all.
The solenoid sends + down A side when you winch in,
The solenoid sends + down B side when you winch out.
or the other way around. the motor on a winch is reversible, which makes it go in and out.
Think of the solenoid as the forward/reverse switch on your cordless drill.
Have you tried tapping on the selinoid to see if it will work ?
It sounds like it or it could just be a loose connection. Did you check all connection ?Hey Chooglin, I am having the exact same issue as the fella who started this thread. I just held the out button on my switch and tapped my solenoid and just like that it started feeding the winch line out. Hit in on the switch and then out again and nothing. Tapped it and out it came. Does this mean my solonoid is buggered?
Well if you are giving the selinoid a tap and it starts to work , I would say the selinoid is sticking !Connections seem to be all good and tight, no corrosion or anything either.
