well I just ordered my winch and the kfi mount install pics to follow. amazon has some good deals on the terra winches right now.
Will this one fit on our 1000's?
http://www.amazon.com/Superwinch-1145230-handlebar-handheld-synthetic/dp/B003COQAKA/?tag=sxsweb24-20
Great price.
Thanks!
Should be that's what I bought mine to put on, the GVWR of the P1000-5 is right around 3350 lbs. Even with 4 people in it would weigh around 2800 lbs so I would think a 4500 lbs winch would do the trick, especially with a snatch block (which you should have anyway) for a particularly nasty "stuck" that would double the pulling power of the winch.This should be sufficient for the p1000-5 right? I was thinking at least a 5k winch but this is a damn good deal. I already ordered the Kfi winch mount
SUPERWINCH Terra 45 has standard bolt pattern see bottom, it will fit the standard Winch mounts with the 3" x 4.87 " bolt pattern wide spool to boot. Thanks for posting just bought mine too for $300 LESS that the WARN I was looking at with same features.
