P700 Sway bar removal?
JimmyA
JimmyA
1,644
5,504
Northeast texas
Anyone removed the sway bar? Does the rear articulate any better? Does the ride feel smoother?
Mopower58
Mopower58
CST is the Best!
79,561
707,184
Crystal Springs,Ms.
I have a P1K and that was one of the first things I did, it does articulate better but can't tell that the ride is any different but I changed tires and wheels at the same time.
Reactions: JenElio
5,412
24,836
I disconnected the SB on my Talon and, yes, it articulates and rides better. The ride is improved because a SB ties the left and right sides together increasing both spring rate and shock valving over the individual side alone. Since the Talons will never be accused of being undersprung, body lean is minimal wo/SB and I'm not a Racer Dude anyway. It's a free experiment and well worth trying since we all ride differently.
42,991
I haven't done this, but will eventually. Having done this on my 500, I wished I had done it on the 700 before that. I just want to re-acclimate to the 700 before pulling it.
Gator
Gator
The Most Unknown Member
2,487
10,456
Louisiana
I removed the swaybar long ago.
Huge difference. Yes, it sways a little more (not terribly). But in exchange, I get to keep both my kidneys.
Most of us disconnected the sway bar and changed the shocks.
If you want to compare... Lay some 2x4's out in the yard and run over them. Disconnect the lower sway bar linkages and use zip ties to hold the sway bar up. Now go run over the 2x4's again. I was impressed enough to go finish the removal.
1972Demon
6
15
I just did it this afternoon.. probably won't test it till next week.
IMG 20200817 130854360
JimmyA
JimmyA
1,644
5,504
Northeast texas
The best reply thus far! in a day or two I will see! Thank you sir!
Reactions: Mudwing
DBD
DBD
67
141
Pennsylvania
Yes much smoother on softest setting. No more teetering on rocky terrain. Be careful with body roll especially with 4 ppl in cab. I have aggressive 28×10 tires and a 2" lift and have had it on 2 wheels on turf. But as for hill climbing or rocky stuff it is much better. With it removed I've probably avoided a few rolls so far on gnarly trails.
JimmyA
JimmyA
1,644
5,504
Northeast texas
Thank you so much for the reply! It will be a done deal tomorrow!
42,991
I should have mentioned I took mine off a few weeks ago. Yes, there is a noticeable improvement, esp on twisty stuff. It's not (to me) as dramatic as it was on the 500, but on the other side of the coin, the "sway" in the corners doesn't seem that much worse either.
I'd imagine it might be worse on 4 seaters with passengers or with a load in the back, but hauling weight and ass at the same time seems like asking for it anyway, so mine will collect dust in the corner...right beside the 500's old bar.
5,412
24,836
I am manly in a lot of ways, but with a wrench I am more like a 4 year old 😅 . Took me a solid 4 hours to put on a rear light with a rocker switch
I'm not sure on the 700 but the Talon needs both links removed and the sway bar tied up or it will hit the upper trailing arm when articulating.
You can see the upper trailing arm in the lower right with the brake line. The end of the sway bar will hit it if both links aren't removed and the SB tied up. Just an FYI
I 9P5S7w3 L
livefromthetree
livefromthetree
It was a damn good ride. Seriously good.
466
1,309
Mount Vernon Indiana
So all that needs to be done is remove the links and tie up the bar?
Reactions: Isaiah
208,726
DBD
DBD
67
141
Pennsylvania
I did the same thing except I put the bolts back the the frame.
I sprayed the tubes up and down with fluid film, like I do with about every hole I find, or make. That is a great thought though, I'm putting them back in as I type... Well actually taking a drink of beer as I type, in between bolts. At this rate I should finish the beer as I tighten the last one😎🍺
