P1000 Switch Lighting
P
packer58
312
943
N. Cali
Getting ready to finish up switch panel…….. So, where did you guys/gals pick up power for your switch lighting and why …..
Thanks
Scoop
Scoop
5,130
20,280
  3. Talon R LV
All my accessories are powered by a fuse box that is powered either (a) when key-on power is present or (b) directly from the AUX battery. The position of that DPDT switch determines if it's key-on or AUX/direct.
My switch lighting is powered from that fuse box.
Reactions: packer58
66,822
I see no reason to wire the led's to a light circuit. I did my first 700 this way but really didn't see a need afterwards. Them being on during the day has no ill effects. Plus you can only control the bottom light on most common 5 pin rockers.
If your a hunter and want them OFF. I recomend daisy chaining the grounds and having push button switch to open/close this circuit. This would kill both top and bottom led's.
And if you really want to find a lighted circuit. I recomend the tail light wire as it's always on with headlights.
Mark in Northern Iowa
486
2,162
Floyd County, Iowa
kramnella.wixsite.com
I used the information learned from this thread.
and then used a Add-a-circuit Fuse TAP Adapter like this for switched power
Have a good day
Reactions: packer58
P
packer58
312
943
N. Cali
Thanks fellas, i ended up controlling the switch's lower independent or off position led through my secondary fuse panel that is controlled by the club stores AUX/OFF/KEY-ON switch. That way i felt like i had the best of all worlds........
Iv'e been taking quite a few pics during my project and will share them at some point soon, some ideas i might have stole from this site and others will get stolen...oooops, borrowed from me from a member or two.
Thanks again to all that have been very helpful
Hopefully the POIDH sheriff doesn't nab me for my lack of pics................i promise ......there coming....
Reactions: JenElio
P
packer58
312
943
N. Cali
One of my next projects to get done is the bilge fan, I already have the fan and switch but would like to run a thermo switch under the seat for automatic fan kick on at a predetermined temp.........for those that have done this what thermo switches have worked out for you....
Thanks
