P1000 Switch plate question
Tuco69
Tuco69
1,474
7,564
Middle Georgia
Ok guys, better to cut one large opening to work with when installing switches or did you cut out an opening for each switch?
Reactions: BWAF
Cuoutdoors
Cuoutdoors
Executive Member
4,229
15,539
Central Iowa
I cut one large hole. Individual would be a nightmare and not gain anything. The plates are stable if that's what you're worried about.
Tuco69
Tuco69
1,474
7,564
Middle Georgia
Thanks, what I hoped to hear. Waited till I had everything to finish this part of the mod, winch hitting the drive way today!
Reactions: BWAF and Cuoutdoors
Tramguage1
Tramguage1
Texan
7,198
27,847
Somereset, Texas
Make sure hole is just a little larger then needed to clear the switches. Leave as much plastic as you can around the perimeter to mount to.
