Synthetic Rope vs Wire Cable
Gator
Gator
The Most Unknown Member
2,488
10,460
Louisiana
My winch is rated for 50' of 3/16" wire rope.
How much synthetic rope can I get on there.
Gator
Gator
2,488
10,460
Louisiana
Assume I go back with 3/16" synthetic.
322,690
I've been having problems with steel I'm trying synthetic now and see how it goes. I bought 1/4 same length I hope it fits I assumed it would if you're carful loading it. I've never tried it yet so I'm interested as well
322,690
What what? Help I'm new to what you just said?
Make sure your winch drum is rated for synthetic rope, puts more pressure on the drum than the wire.
I did not know that! Please explain or do you have some literature on this?
322,690
I know you can get synthetic to come on our warn's Joe but I guess this makes me wonder. I've never heard this either.
Jason86
Jason86
44
58
Louisiana
Image Image Image
After some quick research this is all that I could find involving the drum and synthetic rope. please provide more information about the drum pressure.
Gator
Gator
2,488
10,460
Louisiana
You (or the guy that has to handle the winch hook) is going to LOVE the synthetic. I will never go back to cable.
Reactions: Tflynn
322,690
@Gator do I'm assuming you did get that on and like it?
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
I've never heard anything about pressure. Only heard when switching to synthetic from steel you need to be sure your drum (and any snatch blocks you'll use) is smooth and has absolutely no burs etc. Also if you're switching to synthetic you should change your roller fairlead to a hawse fairlead. I wouldn't be worried @CumminsPusher
Reactions: CumminsPusher
322,690
I knew about the fairlead but I hadn't thought about the burrs so thank you. I didn't understand on the line pressure never heard of that. Wish me luck I'll see if I can get through a weekend without snapping something. Thanks again @Tflynn!
Reactions: Tflynn
Gator
Gator
2,488
10,460
Louisiana
I have used synthetic on all my ATV's. I think they are great. Now I want to change out the cable on the Pioneer.
Back to the original question on this thread. The warn winch has 50' of 3/16" cable. I'm wondering if I can fit a little more rope if I change to synthetic. 60-65 feet might mean the difference between being able to reach a tree of not.
Tflynn
Tflynn
Not a liberal
2,501
3,831
Northern California
I doubt you could fit that much extra. Why not just carry a tow strap as well? That's what I do. Tow strap, tree strap, maybe a chain, d-rings all in addition to the winch.
sharp
sharp
3,757
14,955
Tennessee
They will both be fine just remember to spool in and out from the bottom of the winch spool for longer winch life!
Gator
Gator
2,488
10,460
Louisiana
We carry a lot of gear for winching. I often choose my path based on distance from a tree. We all have tree straps, 20' tow straps (usually 2) and I have an old synthetic rope that my boy broke 10 feet off of.
We have had to daisy chain 4 bikes together, each with 50 winches, to reach a tree.
amc019
amc019
480
592
Little Rock, Ar
Back when I spent a lot of time on the Rzr forums, I read multiple posts concerning drum strength with rope vs cable winches. Apparently, when the steel cable is spooled on the drum, it doesn't tighten down on the drum when under load because it doesn't squish together so to speak, it takes a lot of the pressure as the cable strands are layered on top of each other . Rope on the other hand is able to squeeze together as it gets tighter and doesn't layer up as well, which has been known to make some drums crack under load.
Reactions: joeymt33
322,690
Ahhhhh. That makes sense I was racking my brain and the Internet looking. I wasn't super worried but I do listen to things I don't know:) I'm glad you don't spend as much time there anymore!
Reactions: joeymt33
