P1000 Synthetic Winch Cable vs Syn Plow Cable
Scuba0331
Ohio
Hello, I am installing a Denali Pro Plow. I am using a Viper Elite with synthetic cable and a plow roller. Is it necessary to use the 12' synthetic plow line that came with the plow roller in replace of the synthetic winch cable? If the winch cable is used does the nylon protective sleeve at the end of the winch cable need to be removed?
Thanks!
Reactions: sharp and BWAF
OnTheJob
OnTheJob
426
925
Bristol, NY
I have the same set up. I went with the shorter one because I believe they are looking to reduce wear your long main line because it's a lot of in and out in just a short section. Yeah It's a little bit of a PIA to swap them out and if you need to winch yourself out to swap them back to the long one, including the pulley fairlead. I'll try it out this way this winter and see how it goes.
Scuba0331
Ohio
Update: I received an email from the MotoAlliance tech team. I was told since I am using the plow roller I could utilize the winch cable. I was told push the abrasion sleeve into the winch 5-6 feet so it would not interfere with the rollers.
Hope this helps!
Thanks
Reactions: sharp and MMW
tjoreo
tjoreo
1,032
1,992
Southern Idaho
One thing I have done and it seems to work very well, is use a piece of 2" tow strap from harbor freight to lift the plow. I leave my full length synthetic line on the drum, remove the thimble and hook, then slip a 6 foot piece of the strap through the eyelet. The flat doesn't mind the angle of the pull and doesn't rats nest if you let too much line out. I've been using it for 2 years now with no problems and if I do need the extra lenght, I just pull it off and use the line underneath. One thing is you need to make sure you have enough room on your drum, but a couple of wraps of the strap doesn't take up much room.
OnTheJob
OnTheJob
426
925
Bristol, NY
Short line with the pulley:
Ae778c03 7f82 4f5a 8c3b ee11dc897eb0 jpeg
Reactions: Scuba0331 and BWAF
