Talon 1000 Frame Stiffener/Gusset Kit | SuperATV
Moab_Marty
Moab_Marty
34
40
Moab + Western CO
1. Has anyone installed the SATV Frame Stiffener kit on their Talon?
2. Any comments about use with HDPE skid plates ? ( non SATV brand)
Link to product Instructions:
I am interested in using the stiffener with my Existing 3/8" Factory UTV UHDPE Slid plates.
I checked with SATV tech support and all they could tell me that they "don't test these with other manufacturers products".
I am wondering about a potential spacing issue with the front section of the FUTV plate when adding the thickness of the SATV plate and carriage bolts,
Elkhunter
Elkhunter
345
453
Minnesota
I installed it with the Honda 1/4” accessory skid plates but they are 3 piece unit and I just left the front section off. If yours are one piece I don’t know why you couldn’t run it over the top and add a few fasteners if you need to. 7a09f25252f721dc939376eafbc9282c
Lil_Steve
Lil_Steve
544
2,109
Gilbert, AZ
I have the SATV frame stiffener kit on my Talon along with the 1/2" Trail Armor skid plate. The frame kit will sandwich between the skid plate and the frame, I had no issues but I did sand down the square edge of the front of the skid plate to make it less prone to catching on rocks.
IMG 20220126 095316172 1643216377624 XL
IMG 20220126 095437212 1643216377386 XL
IMG 20220126 095455653 1643216377078 XL
Moab_Marty
Moab_Marty
34
40
Moab + Western CO
Thanks for the response and pics.
I'd like to use the extended front of the FUTV skid to help slip over obstacles which is why I chose the FUTV plates in the first place. Think it may take some drilling and spacers
Reactions: Remington
SuperATV
SuperATV
1,365
9,544
Madison, IN
www.superatv.com
Our frame stiffener works with "most" of the other aftermarket skids I've seen. Any that have a separate piece that mounts in the same section...front section, should work just fine without any modification if you leave the front piece off. If not...you can just cut off whatever you need to on the skid to make it fit up nice and look good. That stiffener is definitely a good idea now though. Better sooner than later.
ChadD
ChadD
25,829
252,510
Brown City
But do they come with stickers? 🤔
#NTC
