I tried to tell you politely that you were not correct but you couldn't leave it well enough alone so here you go again talking nonsense out of your ass. You have absolutely no clue what the hell you are talking about. I told you to go back to the Pioneer forums and f***ing stay there last week for this very reason. You are injecting Pioneer garbage here in the Talon forums and confusing the OP and he will end up with the wrong wheels if he listens to you.
You cannot simply measure the offsets on the Talon and use the same because the stock wheels and tires are different widths. The factory offsets are 50 mm front and 33 mm rear and if you use those offsets with the same rim widths on a Talon you will end up 2 inches narrower in the rear.
So, once again, go back to the Pioneer forums and quit confusing these poor new Talon owners. Your advise here is not accurate or welcome.
@ENZO, do not listen to Smitty335. His advise will cause you nothing but headaches. There is plenty of correct information about wheels/tires for the Talon here on the forums . I wanted my width to be exactly even without spacers so I created a spreadsheet and found out it is impossible with the current wheels on the market. You can only acheave even width on a Talon with the same offset wheels and 1.5" spacers. Here is how it breaks down on the Talon...
First off, don't rely on the X+Y type offset, they are not accurate and different between manufacturers.
I have done a bunch of research and measuring and came up with the following.
- Talon tires are not 9" and 11" wide, they are 8.7" and 10.6" so your overall width may end up a bit wider than expected if using a true 10" wide tire by about 1/2 inch or more.
- All measurements below are for the R model and assume a true 10" wide tire. However, the offsets and width differences apply to the X model.
All stated X+Y offsets are not what they appear to be so you should really go by the metric offset. For instance...
STI's 6+1 is 50mm offset which is really 5.5+1.5
STI's 5+2 is 30mm offset which is really 4.75+2.25
STI's 4+3 is 0mm offset which is really 3.5+3.5
System 3's 5.5+1.5 (sometimes marketed as 6+1) is a 45mm offset and is actually 5.25+1.75
System 3's 4+3 is 15mm offset and is a true 4+3
Front track width is the most important to try to remain as close to stock as you can for handling/steering purposes. You want the tire scrubbing similar to stock or as close as you can get it. That is why STI came out with the 50mm (6+1). If you run a STI's 6+1 Offset with a 10" wide tire up front, you will achieve the factory track width but will be 1.3" wider overall in the front. This is the best offset to maintain stock front end geometry.
The System 3's 5.5+1.5 offset with a 10" wide tire up front, your track width will be .4" wider and 1.7" wider overall in the front. If you run a STI's 5+2 Offset with a 10" wide tire up front, your track width will be 1.6" wider and 2.9" wider overall in the front. The rear hub to hub width is 3.1" narrower than the front. Your best bet is to run the same rims front and rear and get 1.5" spacers in the rear. That way, your overall width will be the same font and rear and you can rotate your tires as an added bonus.
If you don't like spacers or don't need to rotate your tires, these combinations are currently available that make the front and rear similar in overall width without using spacers..
Thanks! I appreciate the info..... this is exactly what I was looking for.
