hondabob
The Upper drivers side A-arm bushing failed at around 32,000 miles. I replaced them with the aftermarket bushings because the stock bushings are difficult to remove and install. The lower A-arm bushings had a little play so I replaced them too. The passenger side was still like new. My dealer said they had to check everything and make a warranty claim. I told them to replace the leaking water pump too. My steering rack had some slight play. They turned in a few more parts to be replaced under warranty. When I installed the A-arm bushings and found several of the parts were still like new I was pissed. GOAZ just bought out my dealer. The new guys suck. The Honda Tech line manager said they couldn't refurbish to whole front end due to the mileage and turned down the bushings. Tech line also said my warranty is still good. The excellent Honda tech with 7 years of Honda experience just quit so that was the last straw. The new tech replaced the left front dif seal on my 2020 Talon with the improved 2022 seal. He forgot to add dif fluid and I know that happens occasionally. Fortunately I check most of my repair work so no problem. It did have 5 ounces of oil, I had to add 8 ounces to bring it up to the full level. I canceled my extended warranty on both Talons and will be doing all my own repair work. I only bought the extended warranty because I was going to put 50,000 miles on both Talons. The service writer said Honda turned down my warranty and it would have cost around $6,000 or more to do the repair work. they wrote up. I knew better and checked with the service manager and found they turned down the bushings, steering rack, and rear wheel bearings. FYI the Honda steering rack will last around 15,000 miles. I expect installing new bushings will fix it.
