Talon Talon alignment
N
Nick179
9
11
Central Valley
Hey everyone just got my new Talon a couple of weeks ago I went with the R model..my first SXS...so far I am having lots of fun
I did notice that my toe in is pretty extreme, does anyone know what the toe in is supposed to be if any? Mine is currently at 3.5 inches and that seems wrong to me and the wheel will shake a bit on long stretches of dirt roads or pavement
Thanks for any help
0D4F9373 DA93 4907 95B6 A7B1A7160D74
Neohio
Neohio
Beast of the East
14,587
73,814
Painesville Ohio
Alignment according to manual is 0.0" toe.
N
Nick179
9
11
Central Valley
So I fixed the alignment, Mine was way out and i got it to 0.0 and what a difference it made it handling!!
Obviously though.
This is my first SXS so I am still learning, and will continue to learn. thanks for the help
The reason I mention it, Check your alignment, I am sure there is more from Honda that are out. Again mine was 3.5 inch toed in!
  • Wow
Reactions: CID and Arizona
nm6r
nm6r
78
173
Sandia Park, NM
I was talking to the salesman and noticed/pointed out the alignment issue. Service took care of it immediately so we continued to close the sale. How is this not something checked/addressed during inspection and prep?
F
fartsalot
223
337
Near the Kansas Nascar race track
After I took delivery and got home with my X I found the sub trans to be low on oil and the coolant reservoir had about one ounce of coolant. The dealer did nothing to check it out and just assembled the parts that needed to be installed. I paid big bucks to them for delivery and set up,,,, I got cheated .
Reactions: CID
David_T
I just got a talon R and I was wondering if any one has had a problem with rear toe out? My left rear wheel has toe out while my right has toe in.
PaulF
PaulF
1,462
4,814
I would check it again on an alignment rack (or another alignment rack).
There is no adjustment for the rear so if it is off, something is bent. If both sides are off in the same direction in a similar amount like you suspect, it is most likely a bent frame.
