Talon Door Latch Broke - Fix
hondabob
1,272
5,045
Prescott Valley, AZ
I have seen 4 of these broken door latches. Mine just broke on the passenger side. I'm getting close to 42,000 miles so I will be adding a fender washer to the driver's side too and also on all 4 doors on my 4-seater. To remove the door panel, you only have to remove a few Phillips screws.
20241122 095543
20241122 100057
Hometeam
Hometeam
985
4,063
Normal, IL
View attachment 450576View attachment 450577
Thanks for the fix! I believe we have the driver-side broke on our 35k mile talon also and I was trying to think of a fix!
hondabob
1,272
5,045
Prescott Valley, AZ
My driver's side door was still closing but broken also. The plastic was damaged from the movement, so I drilled a hole and added a 5mm bolt through the plastic to align and tighten it. I'm going to put 50,000 miles on my Talon R 4-seater so I'm adding the washer support now at a bit over 5,000 miles.
20241123 134109
5,446
25,061
Taking Bob's idea a bit further (because I can weld and tend to over-fix anything that breaks), I'll cut an overlay and edge weld it wherever I can get the torch tip. Any overlay should have pointy ends because a straight weld across that strap 'might' break again. It's a common practice when welding on a vehicle frame. I might even skip welding the two points, doing the top and bottom edges only.
It looks like the ? box can be removed with two bolts allowing better weld access?
1732408495175
Reactions: JACKAL
Hometeam
Hometeam
985
4,063
Normal, IL
We have stick from the trail wedged in behind it holding it for now…..yes we are Rednecks!!🤓🤪😂
Reactions: JACKAL
