Talon Door Latch Broke - Fix
hondabob
1,307
5,198
Prescott Valley, AZ
I have seen 4 of these broken door latches. Mine just broke on the passenger side. I'm getting close to 42,000 miles so I will be adding a fender washer to the driver's side too and also on all 4 doors on my 4-seater. To remove the door panel, you only have to remove a few Phillips screws.
20241122 095543
20241122 100057
Hometeam
Hometeam
1,025
4,326
Normal, IL
View attachment 450576View attachment 450577
Thanks for the fix! I believe we have the driver-side broke on our 35k mile talon also and I was trying to think of a fix!
hondabob
1,307
5,198
Prescott Valley, AZ
My driver's side door was still closing but broken also. The plastic was damaged from the movement, so I drilled a hole and added a 5mm bolt through the plastic to align and tighten it. I'm going to put 50,000 miles on my Talon R 4-seater so I'm adding the washer support now at a bit over 5,000 miles.
20241123 134109
5,684
26,025
Taking Bob's idea a bit further (because I can weld and tend to over-fix anything that breaks), I'll cut an overlay and edge weld it wherever I can get the torch tip. Any overlay should have pointy ends because a straight weld across that strap 'might' break again. It's a common practice when welding on a vehicle frame. I might even skip welding the two points, doing the top and bottom edges only.
It looks like the ? box can be removed with two bolts allowing better weld access?
1732408495175
hondabob
1,307
5,198
Prescott Valley, AZ
The latch part costs around $20. It is the same part from 2019 to 2024. I expect they will all break so adding the support washer may be an easy fix. The side net will keep the door closed. I used a ratch strap to keep it from rattling. Welding additional support will be a good fix.
5,684
26,025
I think adding a washer before it breaks might prevent the problem from ever happening.
hondabob
1,307
5,198
Prescott Valley, AZ
The newer Talons have a bolt with a small washer. It just covers the elongated hole. I added the larger washer on my 2023 Talon R 4-seater. Several of the Phillips screws that go into the plastic outer door were stripped. I will be installing slightly larger screws to fix it. The bottom picture is my 2019 with the bolts without the washer.
20241124 102038
20241124 103744
20241124 101914
20241124 102305
20241123 134109
