Talon Front Drive Shaft U-Joint Failure
NTCPrezJB
NTCPrezJB
President of #NTC
100,668
899,475
Canton, OH
If the cap hasn't fallen out they wont replace it.
I know a guy that can help finish off that driveline for ya so that they will replace it. 🤣😂🤣
5,031
22,492
Like this, Bob's photo -
1658431870501
56,744
Does anyone know if the honda extended warranty covers this drive shaft? I have 2000 miles on my '19 Talon X and it sounds like the shaft is rattling like crazy at a steady speed.
@Plumber32 had the cap come all the way off yours when they covered it? I want to say yours did throw the cap off but couldn't remember.
hondabob
1,162
4,538
Prescott Valley, AZ
Honda had several oversized yokes allowing the bearing cup to be hand assembled. The retainer clip will get spit out as the bearing cup turns. The bearing cup must have a proper press fit. My dealer let me get my 4th drive shaft spot welded. My other Talon is still ok with a bit over 6,000 miles on it. I marked the bearing cups and they have a good press fit. I carry a saw to cut the driveshaft in half so I can pull the drive shaft off the sub trans and drive it out in 2WD. With a 9 inch blade the drive shaft can be cut by going through the coolant drain hole in the skid plate. Paul F did a study and found several defective oversized drive shaft yokes. This one was beat up pretty good driving it 3 miles at low speed.
Honda Tech you should ask for another tech line tech that has experience installing a drive shaft U-joint. Techline can call in a couple of driveshafts and take them apart for inspection. Usually the U-joint at the other end will have a good press fit. Not all but most of the drive shaft failures I have seen are at the rear U-joint.
It was 45 years ago when I worked the powersports tech line for Honda. I worked my last 12 years on the Automotive tech line. We were ASE certified in everything. It was important for the tech line guys to install some warranty parts for testing and experience. Honda also had a model engineer for a difficult problem.
U joint5 Welded6
View attachment 345001 View attachment 345002
They've called back several of ours, but the consensus from most of our Honda contacts is there isnt any issues with driveshafts.
To be honest most of the TECHLINE guys are uselsss.
Dankathy
286
822
Some of my caps had rotated slightly at 2000 miles, the shaft was removed and tack welded. Now over 14,000 miles, no failures.
