Talon R 13,000 mile report
PaulF
PaulF
1,462
4,810
1.35 Quarts (1 Qt., 11.2 Oz.)
No filter but make sure you pull the correct drain plug. There are 3 drain plugs and the Sub-Trans is the most forward one and clearly marked on the stock skid plate.
Reactions: Bo_Darville
208,011
YEP! And if you think you need a 14mm, your in the wrong hole!
TMCCOY
27
34
I have Paul's shift gate and highly recommend it. The moly oil is on it's way too.
Reactions: TalonR65
ManofManyStangs
16
10
P'Burg KY
Just curious if you have ever experienced any low gear issues?
NFA_Fun
NFA_Fun
81
95
Pinetop, Arizona
Asked dealer about the 10-14 moly in the sub trans. They said no.....and from what I gathered it was due to them buying 10-40 in bulk to service engine, trans, and sub trans.
Moly oil on the way too!
Reactions: TripleB
TMCCOY
27
34
Put the moly in this weekend along with a fresh set of filters and 6.5qts honda synthetic. Runs great!
Reactions: Mopower58
