Thanks for the heads up!FYI: The "kits" come in .05mm increments and the OEM shims are in .025mm increments so you will not be able to get as close to specs with the aftermarket shims when you need one of those "in-between" shims. If you need a 2.125mm, you will be stuck making a choice between the 2.10 and 2.15
My dealer claimed they had the OEM shims but turned out they only had the HotCam units despite me specifically asking before I got there. Call your dealer, YMMV.Do the dealers have the shims in stock or is it order and wait.
