This is completely normal, right?
Eltobgi
Eltobgi
4,599
15,187
North Dakota
@JTW think back to initial install on the a arms and joints....Now did you possibly over ream them? I know It was required when SuperATV first offered them!o_O
Reactions: JTW and Russ989
lee
lee
Village Idiot
2,443
13,833
Springfield Ohio
You might want to keep this guys number handy.
I've been facinated with his videos for the last few days.
Thinking I might quit my day job and go do this.
Russ989
Russ989
22,645
147,291
Yes.. they should have to be pressed in and out. But mine is a little loose from the jam nuts backing off the T’s. I was just being facetious
Holy crap, I just watched your video again. I didn’t notice it moving the first time I watched it. You need some parts.
Reactions: JTW
Kilo427
Kilo427
1,543
6,441
If only you were coming to my house with a shop a lift, extra ball joints and a guy that just replaced all his ball joint in the last 2 days....
Lol.. we should all prolly save that.
I took it to a shop and had them press them in. I figured they would do a better job than I could having the right tools.
I also went thru and red locktited all the other jam nuts and used a BFH and wrench to snug them up. I was surprised how easily the nuts moved on all but a couple. I also found the inner tie rod nut under the boot on the drivers side had just about come off! I had noticed a little play developing in my steering at Takeover. And well, I found the culprit!
Kilo427
Kilo427
1,543
6,441
good make sure you red loctite everything before we look at it and replace the ball joint. Makes it more challenging
68,241
Drill a hole and put a crater key in it. That will fix it.
Reactions: JTW
68,241
I bet a ball joint is where my light thump I'm starting to get is coming from.
Reactions: JTW
