P1000 Tire Comparison - anyone done one?
OnTheJob
OnTheJob
426
925
Bristol, NY
1. Has anyone done a tire spec comparison? Actual height, width, weight? Maybe a spread sheet?
2. Where do you think is the best place to buy tires online? Price and shipping. Dealership is $$$!
3. Are you guys mounting them your self or having someone do them for you on your stock rims? I have 12" steels that I want to keep. What about these self balancing beads? I got them on motorcycle last summer and they work great for that application.
Thanks guys. I tried searching but there is so much I got lost for about 45 minutes.
Reactions: Isaiah
43,293
One of the online tire sites (mud throwers maybe?) usually posts some actual numbers. Most will give them to you if you ask.
I agree, a nice site or page dedicated to this would be cool.
Reactions: Isaiah
JimmyA
JimmyA
1,644
5,504
Northeast texas
I have been using the beads also on my 2wheeler for years, not needed on the pioneer.
Russ989
Russ989
22,642
147,257
We should compile the info here. I’ll start
30x10-14 K9 Super Grips, measure 29” tall at 11psi.
Reactions: Rick53 and Isaiah
L2R
L2R
Understanding women Vol. 1
1,063
6,599
East of the Appalachians
There are infinite set ups with tires/wheels/offet etc. It is endless.
I've haven't seen a comprehensive spreadsheet but one would be nice for someone to do while figuring it out.
This isn't an easy task and you will have to think thru many things to filter it down for your needs.
It can be frustrating as there isn't a quick, easy answer and as you ask 1 question. you will get 3 back.
-DOT matter to you now or in future?
-Rock crawling or turf or hard tops
-Tread pattern
-Mud digging or sand? Thread matters
-TIre manuf. you prefer
-Wheel size / replacement and offest
-Is rotating them important to you?
- how many plys on side walls, for road use or rock crawling, it all makes a difference.
Or find someone riding where you do and see what they use. :)
good luck.
Reactions: Napaul and Isaiah
OnTheJob
OnTheJob
426
925
Bristol, NY
-Tread pattern
good luck.
I actually started a spreadsheet yesterday for what I am looking for. I know it sounds crazy to some, but I want to stay with a stock size tire: 27x9x12 in the front and 27x11x12 in the back. I don't need anything taller and I don't want my speed to suffer with heavier tires. All great points and questions because my spreadsheet would probably only be helpful for less than 10% of the guys on here. I'll attach it if anyone one is interested in my results. I got the numbers from various websites. I am waiting for Quadboss to get back to me because their numbers were no where to be found.
Here are my requirements:
-This is a farm machine that we also like to run on the property for fun
-DOT does NOT matter here in Upstate NY
-No rocks, no deep mud, no sand - lots of farm fields and heavily wooded rolling hills
-Has to be good in snow
-Use breakdown: 50% trails, 25% turf, 25% pavement
-I am riding on OEM tires now and I do not have a manufacture preference.
-I don't have to rotate
-I've never had a flat on the 4 plys now so extra plys are not needed but would be nice
- I'm a cheap AF so I'd like to go with best value
I'd ask someone around here but UTV's are not as prevalent around here.
Edit: I am just seeing the Sunf tires. Anyone know anything about those?
  • Copy of UTV 27x12-3.xlsx
Reactions: Isaiah
L2R
L2R
1,063
6,599
I like my terribites. they don't tear up turf as badly as OEM and ride much better on hard surfaces.
what I have seen so far, they work well in mud but there should be more about mud a snow on them from others.
ehart814
ehart814
1,655
3,645
NWPA
I just put some truck tires on my buggy. The guy that mounted them put balance beads in the tires and I would highly recommend them. The factory tires would shake when going fast down the road. The new tires with balance beads are super smooth. Zero shaking all the way up to 66 mph. I'd definitely recommend balance beads.
OnTheJob
OnTheJob
426
925
Bristol, NY
Good to know!
Reactions: Isaiah
Napaul
Napaul
56
112
Did yours come with the OEM Bighorns? If so, how do you like them? Did they do everything you needed them to do? A lot of people are really big fans of the BH2 tires. If they worked well for you, go with what works and just order another set of those.
Reactions: trigger and Rick53
OnTheJob
OnTheJob
426
925
Bristol, NY
Yes they have the Bighorns. I like them except the front tires are wearing to fast from the pavement. An option would be to to just put a new set up front because still have some life in them. They aren't the cheapest tires either. Not feeling I got a lot of value out of them is all.
I added the Sunf tires. Quadboss has to gotten back to me.
Reactions: Napaul
William
William
1,442
2,887
Flowood MS
I like bighorn 2.0... I’m getting 28 blackwater evolution next....
Reactions: trigger
tincangob
tincangob
200
270
Central Wisconsin
Good to know!
I have a 2018 P-3, and the original, aggressive front tire are really getting bad. The rear tires are still good, and I'm wondering if I can put less aggressive tires on the front and keep my original rear tires on the machine. I do about 90% of riding on paved roads since we don't have many trails around here. I would even consider truck tires on the front if that would work.
Tire recommendations?
Sjc3081
Sjc3081
263
442
Wappinger NY
Kanati Mongrels or the knock off Tusk Terrabites. Search their reviews.
Reactions: tincangob
208,730
Front end is out of alignment and why did you buy a trail buggy to ride on pavement?
tincangob
tincangob
200
270
Central Wisconsin
Frankly I didn't realize how few and far between the trails are in southern Wisconsin. Further north they have a lot of trails, but we must drive 2 or 3 hours minimum to get at them. If I had another chance, I'd most likely get a different machine. But I gotta dance with machine I bought. We have a vast variety of routes available here but very few trails.
I will check out the alignment.
  • Sad
Reactions: CID
Napaul
Napaul
56
112
I agree with Smitty on the alignment. Get me straightened up and they won’t wear nearly as bad. You also mentioned truck tires...if you’re riding mostly roads I would highly recommend them. I just put some LT mud tires on mine and it’s a night and day difference. I still ride mostly off-road, and they are capable there, but on pavement it’s almost like a car now. I’ve even seen some folks run all-terrains on theirs, which might serve your purposes better.
208,730
What pressure you running and do you have bead locks?
Napaul
Napaul
56
112
I’m currently at 15 PSI. I heard a lot of conflicting stuff about beadlocks vs non beadlocks with LT tires. I was pretty convinced to go with beadlocks until I found some non beadlocks I really liked on sale, so I thought I’d try them. I started out around 25 PSI, observed how they flexed for a while on some of the stuff I ride on, then lowered to 18 and observed for a while. Satisfied and confident, I lowered to 15. I’m still observing them at 15 for now, but plan to go lower. I haven’t seen any flexing that has concerned me so far. The ride below 18 is fairly smooth and getting smoother as I go down. At 25 you will break bones. Lol
Reactions: Russ989
ehart814
ehart814
1,655
3,645
NWPA
I was at 14 for a while and it was still really harsh. Here's what I did. I let air out of the tire until I could start to see the tire flex at the ground. Then I checked pressure, 9 psi. That's where I have had them set ever since. Huge difference between 15 psi and 9 psi. Much smoother ride, and actually quite a bit more traction in the woods from the flex and larger contact patch.
