Hi everyone ,hopefully someone can help me out .I want to put 814 shocks on I was wondering if I could run 29 in terabytes without putting a lift, just using the lift from the shocks running stock rims 14-in. Thanks in advance.
Not sure about the 814’s bit with the fox shocks and dome pre load you most certainly can. One way or another I would get some wheel spacers to help with not rubbing while turning. Youll still be close either way and might rub on some bumps and stuff. Bit ultimately your better off in the long run with some new arms to go with your set up.
