Tire size help
I
iam_canadian22
20
23
Hey guys im looking at putting a set of zilla's on my p5, 11 wide in the back and 9 in the front, will be on the stock rims. Im unsure of how tall i can go. Ive been doing some research but cant find a definate answer. Will 27's fit without doing the frame mod or should i get 26's to be safe?
Reactions: BigJohn
393stroker
393stroker
30
19
Image Image Image
27" Will fit with no rubbing and no frame mod.That is what size I am running.I have since went back to factory rims with these tires. It felt like to me it made the steering a lot easier and also the trails I ride are so narrow and heavily wooded.
I
iam_canadian22
20
23
Thank you very much, cant wait to order them up
265,435
I
iam_canadian22
20
23
Will do, will only be in about a month and a half when im back to work from tradeschool
393stroker
393stroker
30
19
Glad I could help. Hope you like the new tires.
393stroker
393stroker
30
19
Did you use any wheel spacers?
No wheel spacers. Actually when I had the aftermarket rims on they would barley touch the frame really the plastic belly pan at full turn.You could not even hear them rub. And when I put the factory rims back on I gained about 3/4" clearance.
