Talon Tires on stock X wheels
Z
Zurf
7
9
Centralia, WA
Do 30x10 tires clear on stock 1000X wheels? What’s the tallest you can go with 5/2 offset front?
Thanks..!
Z
Zurf
7
9
Centralia, WA
Thanks..!
Point me in the right direction...
I’ve read every post I could find on tires and wheels. Most of them fail to mention if it’s an X or an R or what the wheel offsets are. Or even if they’re running spacers. Thanks.
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
You are not going to get an accurate answer to your question because there are too many variables between manufacturers (both tire and wheel) and not every combination has been tried.
Keep in mind that 30" tires range from 29 to 31 inches and 32" tires range from 30.5 to 33 inches depending on manufacturer. So when someone says I run 32's, you need to know what brand.
Wheel offsets are also not accurate. a 7" wide wheel with a 50mm offset is truly a 5.5+1.5 and not a 6+1 like many advertise. And a 45mm offset is really a 5.25+1.75 and not a 5.5+1.5 (or even sometime 6+1) like sometimes advertised. Most 4+3's are actually 0mm offsets so that really makes them a 3.5+3.5. UTV style offsets are all over the place and not very accurate so try to use the real mm type offset if you can.
So, that being said, the general rule of thumb for an X, 30's will clear and most 32's will rub slightly, even with 5+2 wheels. Offsetting the wheel out also makes the tires scrub/arch further back so you don't gain all that much fender clearance by spacing the wheels/tires out anyway.
Reactions: jamesh
Z
Zurf
7
9
Centralia, WA
Thanks Paul, pretty much what I thought. I just ordered some STI HD9, 6-1 and 4-3 along with some 30” Carnivores. Will report back when I get them.
PaulF
PaulF
1,462
4,817
  2. Talon R4 LV
That setup should work just fine on an X. You will end up about 1" wider on the front and 2" wider in the rear.
Post some pics!!!
Cowboy02
Cowboy02
60
136
Northern Ca
  3. Talon X
I'm looking to do the same set up using STIHD9. Did you get 15's or 14th?
Dragon21
Dragon21
1,309
2,920
Raleigh, NC
Just ordered 29" carnivores to go on stock wheels (Measure 29.7"). Ive seen that 32"s rub slightly so wanted to play it safe
Reactions: Cowboy02
Z
Zurf
7
9
Centralia, WA
I went with the 14’s. Fit fine..
5d084aef a3af 417e bd4e 3996b793e883 jpeg
Sheetmetalfab
Sheetmetalfab
2,454
15,683
Alaska
Z
Zurf
7
9
Centralia, WA
STI HD9’s the STI part numbers are 14HB929 and 14HB928, that’s for a 6-1 offset in the front and 4-3 in the back. 30x10x14 Maxxis Carnivores. 7”wheels about 65”
wide
Reactions: Cowboy02
