P1000m5 To lift or not, wheel and tire size
Hendi1977
Hi there, relatively new to the sxs game here, have a 2018 LE I bought new. Just returned from a trip to the Black Hills, was great, but realized after some rock climbing, I would like a little more ground clearance, better wearing tires, and probably wheels to set it off. Just wondering if anyone had some good suggestions?
Hendi1977
The 2018 LE already has full skid plate underneath, although I would like to add a set of rock slides. From what I've read so far, I could go up to a 30" tire if I do the forward A arms & 2.5" lift, if that seems correct to ya'll? If so then my next question would be what size wheels & brand of tires to go with for a beefy look? Somewhere I saw a tire called Renegade, I believe in 8 ply, that looked like the type of tread I think I want.
Reactions: Haldog77
116,516
Few things, Is your skid plate aftermarket or stock? If its stock, u should ditch that G string of a skid plate and get a much better aftermarket one cuz that stocker wont help u but on a gravel road.
Yes u can go with 30’s with forward arms. Id stay away from the lift especially if your gona get arms. The lift changes the geometry of the suspension amongst other things and can make for a more harsher ride. You have an LE so you say? (will revisit that later lol) so you have fox shocks. If you do the arms, just add some preload to those Fox’s and get your added lift from that.
Tires and wheels. Im not opening and most here wont either, that can of worms lol just use the search for best tires and wheels up top and get u your beverage/beverages of choice and get ready for the show! lol.
Back to the LE.
Your first post here..Welcome to the best forum on the planet.
We have an unspoken gospel around here when you first post…
Pics Or It Didn't Happen!
Haldog77
Haldog77
NTC's Mafia Enforcer (Ret.)
43,570
366,354
Bossier City, Louisiana
Welcome from NW Louisiana.
I read an article once that said LE's don't like lifts. Offset A-arms are fine, but lifts cause issues. There are several good threads on this forum about tires and rims. Good luck.
#NTC
SuperATV
SuperATV
1,671
12,187
Madison, IN
www.superatv.com
Like the boys above said...you'll want to stay away from a standard lift on the LE model. You're out of luck on aftermarket axles for the LE, and the stockers are dinky little guys that don't like much angle. If you wanted...you could go with a portal lift down the road...but that's a hardcore addition and whole other worm hole. Skids, Arms, Tires...and send it. Then get some tie rods...cuz those are gonna go next. Lol!
Haldog77
Haldog77
43,570
366,354
That's the best I have heard so far. "Skids, Arms, Tires,...and send it."
210,943
Welcome! No lift.
Ridinfool
Ridinfool
36,144
386,049
Western North Carolina
I agree on the no lift deal… you said you were doing rock crawling, the LE’s have an aluminum skid plate from the factory, some guys swear by them others don’t, I’m an others guy. Metal bends and stays bent, I have the 1/2” HDUM (I think that’s what it is) skid plate and it slides great over everything, as far as a lift goes… when you go up you must go out. (Wider width ) or you will be tippy.
Skid plate, A arms, bigger tires you should be in good shape . Wheels and tires…🤣🤣🤣🤣
Find you some good bead locks that you think look good and an 8y tire and give her hell.
SuperATV
SuperATV
1,671
12,187
Madison, IN
www.superatv.com
you didn’t offer him the 0% NTC discount???
WTF??? 🤦‍♂️
DOH!! I forgot! I can get you a little discount for signing up here!
Or....you'll get a whole 0% off all orders if you are a member of the #NTC!!
How could I forget?!?!?!
Worse1
Worse1
145
554
Arizona
If he goes with the extended A arms, does he also need to change out the cv axles? Asking for a friend 😁
Reactions: Remington
