rocmar
My steers just fine...The only thing, when changing the original offset, it alters the steering geometry.
Little floaty...
On loose sand..
Little floaty...
On loose sand..
More than that..So with your spacers and after market rims, how much spacing does that come out too vs stock? Maybe 3 inches?
You can call me...You keep getting wider and we're going to have to start calling you water bug! View attachment 38759
Late for dinner??You can call me...
wat ever ya want
57 & 1/2....front
58 rear
big difference. ..
stability. ..traction...
overall ride...good
HaHa....Late for dinner??
You get any wider and we're going to start calling you Rosie or Oprah!
Everybody likes a littleYou get any wider and we're going to start calling you Rosie or Oprah!
Yes...you are correct....Cool thing about that Loctite is, if you ever want to remove the bolts, just heat them up a little (a small pencil torch) and the Loctite will let go.
Can't go wider....You get any wider and we're going to start calling you Rosie or Oprah!
I've used other LOC titeCool thing about that Loctite is, if you ever want to remove the bolts, just heat them up a little (a small pencil torch) and the Loctite will let go.
KoolI used red 271 heavy duty Loctite when I installed 1 1/2" spacers. No problems yet. I also put some on my lightbar bolts. It rattled loose the first ride, no trouble since adding loctite.
Between the spacers and my aftermarket wheels I love the width and stability of my P5 now.
