I didn't notice that much difference at higher speed with the bar removed but definitely some when I first did it. You get used to it. It's worth it for the better articulation In my opinion.Since I started this thread I did get the rig. I have had it up to 30MPH. It's fast enough. It feels unstable but that might be the new tires.
Many of you have removed the sway bar. Does that make it feel less stable at higher speeds?
Could be why I didn't feel much difference. I've got a two seater and rarely do I ever have a passenger. Plus I don't really have anything mounted up high that's heavy. And I've got fox suspension too so maybe all those things together makes it harder to tell. All that being said, I do still carry the links with me in case I decide I want to hook it back up. That's one reason I recommend people at least try it, all it takes is four bolts and a few minutes!Tflynn did you try the disconnect with people riding in with you? Did it feel ok with a load?
