P1000 Trailer help
Corona1
Corona1
319
878
The Land of Cheese
Make you a deal on this one... considering selling in the spring anyways.
I may have to contact you about that, once I narrow down what I'm looking for.
Appreciate the offer.
Reactions: JTW and sharp
Jimmyscoin
Jimmyscoin
114
242
Fairbanks, alaska
I've got a 7x10 aluminum. It's super handy for a trailer. Easily push it by hand anywhere I want. It's a snug fit. If I did it over I would of went with a 6x12.
I am actually thinking about buying a 77" x 12' aluminum. It only weight 680lbs. How do you like the aluminum? It makes me nervous simply because I have always had steel but my nerves have no reason behind them. Just due to being ignorant about the aluminum strength. How does it handle and stand up to abuse? Thanks
Corona1
Corona1
319
878
The Land of Cheese
I've had an all aluminum 12' trailer for about 5 years now. Love it. Went to aluminum because of the excessive amount of salt used here in the winters. Rusty stuff makes me crazy.
Had the same concerns as you. No issues so far. Use it for everything from hauling gravel to 4 wheelers and SxS.
I went with treated deck for ease of adding d-rings etc.
Reactions: sharp
Jimmyscoin
Jimmyscoin
114
242
Fairbanks, alaska
Sounds like exactly what I'm looking at. It has a wooden deck and aluminum ramp. I guess I was just concerned if I start really tightening up the ratchet strap that it would bend the rail. This is the one I am considering.
IMG 0412
Reactions: sharp
Corona1
Corona1
319
878
The Land of Cheese
F62bb0b9cc861899350e61c53600328a
Here is what I use. Can't see the wood deck under the snow .
I generally tie at the lowest points of the side rail stakes when needed, not the rail itself. If you add flush d-rings to the deck, even better.
I'm in process of bending up some front tire chocks similar to what motorcycle guys use. Trying to narrow down quick release system.
Reactions: sharp
KevinSC
KevinSC
286
306
I have to many trailers lol but they all have there purpose. I have a 4x6 I use with the lawn mower, a 7x16 tandem I use for the side by side and lawn mower, a 7x20 car hauler that I got for a steal of a price that I put the tractor on, and a 7.6x28 gooseneck that I only use 2 or 3 times a year, but I have a use for everyone so I will not sell 1 of the other. My philosophy is go as big as you can as it is just like the pioneer, if you buy the 700 you will always want more, but if you buy the 1000 first you will never need anything else. Just my thoughts.
1BadDart
1BadDart
1,415
13,030
W. KY
I look at a trailers as a tools and have the right tool for the job philosophy. When I run the valves on the hot rod I could use my 18" cresent wrench, yes it would work but wouldn't be ideal for the job.
While my 6' X 10' tilt trailer is adequate, IMO it's not ideal as the deck is balanced over the axle and as I mentioned in my other post it doesn't put enough weight on the tongue to pull well. I'll find a 6' X 12' and sell the one I have then I'll be set, for now. LOL
Corona1
Corona1
319
878
The Land of Cheese
I have a 7x14+v-nose that would be perfect for the P1, except the ramp door is only 72" high. Either replacing with another cargo trailer or a toy hauler.
Prefer not to trailer open in the winter if possible. Messy roads up here.
Reactions: sharp and KevinSC
69,050
Zero issues. If I was going to use it alot I would spend the extra on a top of the line one. They definitely are not as sturdy as steel. They flex witch I'm not used to. But the weight savings and ability to move it so easy. Along without being a rust bucket in 2 years is a huge advantage
Reactions: Corona1 and sharp
Jimmyscoin
Jimmyscoin
114
242
Fairbanks, alaska
For most of his life it will only be a weekend warrior. The only time that I will put a lot of miles on it is when I moved from Alaska to North Carolina. But once I'm there it will just be the hall the side by side to go riding And hunting
PioneerPete
PioneerPete
1,496
3,517
Chattanooga, TN
I need to get a trailer for my P1k5. I own a 5x8 trailer and its super handy. I'm debating between keeping this and getting a 6x10 or 12 low side single axle (cheapest), sell the 5x8 and buy a single axle 6x12 higher side or possibly a tandem axle 6x12 or maybe 14. I know the tandem will tow nicer, but it also is more difficult to maneuver by hand. Feedback on trailer experience and more importantly regrets is what I'd like to hear. I have concerns about getting in and out of the Pioneer in a highsided trailer vs a flatbed type design, but like the higher sides for dump runs and bringing extra gear when I take the Pioneer. I will be towing with a F350 diesel, so brakes etc are a non-issue.
I bought a 12' trailer and wish I'd bought the 10' instead.
Jakey
81
139
San Francisco Bay Area
I left out that I also have unlimited access to a 8x24 enclosed car hauler, which I use for hunting trips mostly. I disagree about the never too big comment, the 8x24 is much too big for my purposes, even when hauling a jeep, atvs and 4 guys hunting gear.
I understand the limits of load capacity of a single axle, but I also don't follow those ratings as limits for my use, just a guideline. I understand the legal argument, but know lots of PD and it is rarely even looked at unless it is a blatant overload.
I am hoping to use the pioneer trailer for the same purposes as my small 5x8. Storage is a bit of an issue.
Why do you wish you got a 10' instead? Do you have a trailer with sides or just a flatbed style? Thx
Jediwrathchild
Jediwrathchild
212
410
Kodiak, AK
@Jimmyscoin I bought a 16' tandem from White Spruce in ANC. Really happy with the service from them. I think they may have a store in North Pole a bit closer to you.
Reactions: Jimmyscoin
Jimmyscoin
Jimmyscoin
114
242
Fairbanks, alaska
Yeah, they have one up here. That's where I'm looking at it. I just hate paying the extra cost because it's "Alaska" but I guess if you want one you just have to suck it up.
Reactions: Jediwrathchild
KevinSC
KevinSC
286
306
