P500 Trailer tires
O
oldfortyfive
596
1,319
Illinois
Seemed like the best place to put this...
My trailer came with Loadmaster bias ply tires load rated at C. I've got around 8,000 miles on them and they seem to be doing well, but given that I do a couple long trips a year (3,200 miles round trip on one) I'm thinking I should consider putting new tires on already. Radials seem like the way to go. Anyone have any thoughts or recommendations on tires?
Reactions: sharp
HUCK
HUCK
1,047
2,315
ARIZONA
Bias outlast radials on a trailer in my experience but when got new shoes for one of my trailers (15 s) I couldn't find any bias ply .
Reactions: sharp
O
oldfortyfive
596
1,319
Illinois
What kind of trailer? I'm using a small aluminum open trailer.
Reactions: sharp
O
oldfortyfive
596
1,319
Illinois
According to my trailer dealer trailer tires only last less than half as long car tires and radials last twice as long as bias ply. His recommendation was change them every other trip west in my case.
Reactions: sharp
HUCK
HUCK
1,047
2,315
ARIZONA
Those are on a 12' closed in , but my horse trailer has 15" bias tires on it and they are 12 years old and showing very little signs of there age as compared to 3 yr old ones on my 20' closed in with radials that need replaced do to sun rot .
Reactions: sharp
ncred02
ncred02
1,031
1,769
Raleigh NC
I used to buy tires, and have them mounted on my existing wheels, until I figured out tire and rim combos are virtually same price and easier to do it yourself. They come mounted.
Examples:
Amazon.com: 15" White Spoke Trailer Wheel with Bias St205/75d15 Tire Mounted (5x5) Bolt Circle: Automotive
Amazon.com: 14" White Mod Trailer Wheel with Bias ST205/75D14 Tire Mounted (5x4.5) bolt circle: Automotive
Thanks for that heads up. I may get an extra spare at that price.
I'm not paranoid , but last year when my trip to Tenn. I brought 3 spare tires. I took two of another trailer I had but since sold. Cant be too prepared
Reactions: sharp and Jshell3
O
oldfortyfive
596
1,319
Illinois
The spare tire on my old van was stored in it out of the sun & weather only listed 10 years before it let go just sitting there. I wouldn't trust those 12 year old tires very far.
Reactions: sharp
Moose308
386
289
Maxxis
Reactions: sharp
WillyBill
WillyBill
Wheeling Addict
473
1,887
Clinton, Utah
  1. Talon X LV
IMHO...Go up a Load Range or 2 and try the Sailun S637. I have a 3 axle Cyclone Toy Hauler and that's what most of us are running (Load Range G). Of course you might not be grossing upwards of 20,000 lbs either. The Cyclones originally came with load Range E tires but the factory went to Gs a couple of years ago as did most other brands due to failure rates on the Powerking Towmax they put on them at that time. They are doing at least as good as the Goodyear G614 based on what I see from failure rates in our forums.
Good Luck!!!
WB
Reactions: sharp
sharp
sharp
3,757
14,955
Tennessee
A trailer tire has more to do with age than how much tread there is on it. If it's several years old and still looks good but it's old the probablity of it blowing out on a hot interstate is pretty high. I blew out 2 on the way home from the takeover that looked fine. I replaced all of them with Goodyear marathon. They are on a 14 utility trailer.
rkwerner
62
134
Any tire will last longer in use than just sitting around. The oil compounds in the rubber will be absorbed into the tire and the surface will dry-rot. The act of driving (centrifugal force) forces the oils back to the surface. With consistent use your trailer tires should last a long time especially if they are stored out of the sunlight and you check the pressure before trips.
