Pioneer 500 is there transmission fluid? I got mine wet. Sunk it. I got all water out of engine ect. Im up and running. Just need to know if there is transmission oil to inspect. Pleaselet me know. Thanks
How do u change the Tranny fluid or is it all connected to the engine and therefore when u change the engine oil it automatically changes the tenant oil ?
That member has been deleted for some time and this thread is 5 yrs old. Your the first poster since that time lol.
Try Starting a new Thread for your question.
There is no transmission oil. The transmission is lubricated by the engine oil so in other words, every oil change is a transmission oil change. Hope that helps.
In my opinion to clean the engine/transmission out properly will require you to break the engine/transmission apart and clean it extensively to avoid silt/sand creating havoc 6-12 months from now vs. simply changing the oil 2-3 oil times. As stated above, the oil needs to be wet clutch approved.
