True duel battery
Klracin1
Klracin1
19
54
North Carolina
  1. Looking to buy
Will installing a duel battery set up void the factory warranty? I’ve got 90 miles on my 21 1000-5 and it ran hot with me this past weekend. I don’t think the fan is coming on. Thanks for Info
Scoop
Scoop
5,144
20,334
  3. Talon R LV
Nope, no issue with that as long as you install properly.
On the no fan: Search the forums. Apparently, there was a rash of "they didn't plug it in at the factory correctly and/or bent pin" causing this issue for some.
Klracin1
Klracin1
19
54
North Carolina
  1. Looking to buy
No it will not void the warranty.
We see no pics yet!
PICS OR IT DIDN'T HAPPEN!
No pics. I was worrying more about how I was gonna get it out of the woods. I put 3 20oz bottles of water in the radiator after it quit boiling. The overflow bottle was full. I’ve heard that if the radiator is low that it will not pull the fluid back out of the bottle. Took it to the shop yesterday and they hooked the computer to it and couldn’t see anything that said it ran hot. They have ordered a new fan
Klracin1
Klracin1
19
54
North Carolina
  1. Looking to buy
B69FB189 85DA 4C68 90FC 601455FD4EF0
WagginTail
WagginTail
1,581
5,854
SC
Did they check the plug before ordering the fan?
P1K5Dave
P1K5Dave
2,245
8,426
Petoskey, MI
I'm willing to bet the fan is fine. It's going to take these guys longer to get it right than you would by DIY and reading here.
Look up the info on here and pass it on to them, so you can get your ride back asap.
66,870
Do you ever recall the fan coming on?
Yours is a 2021 model.
With these the common issue related to the fan is a bent pin or a unseated connector.
Check the connector at the bottom of the radiator on the passenger side.
Check the connector under the drivers seat. It will be a 2" by 3" black box. With a 2 pin connector and a 4 pin connector.
Report back.
Next step is to test the actual fan to rule it out.
